Results 1 to 4 of 4
Thread: 4agze idle
    Aug 2010
    Default 4agze idle
    Hi just have a problem with the idle in a ae92 4agze corolla.
    Idle is around 1.5k-2k.
    Tried pulling out the tps plug, no effect, plug back in, no effect.
    Ecu im using is the EMS stinger v4.
    Sep 2009
    Default Re: 4agze idle
    Vac leak?
    bad tune?
    fucked spark plugs maybe..
    I'd be looking for vac leaks first.. There is a screw on the TB to conrol the ICSV wind it all the way in and see if it makes any difference with the ilde.
    edit; also check timing.
    Victoria, Mt Macedon
    I'd guess a vacuum leak post TB (possibly vaccum line that's fallen off). But some more info would help.
    Has it always been a problem? Or did it just start one day? Do you have the ISCV connected? If so how is it driven from the Stinger? etc.
    Hen
    PS - Above suggestion is assuming it's MAP sensed. If it's AFM then ignore. Also would be helpful to know if it's MAP or AFM.
    Aug 2010
    Its MAP, just happened tonight, switched back from a friends airbox so had the intake pipe off and decided to spray some TB cleaner to give it a clean. then when I drove the car at the lights the idle started to rise.
    No visible vac leaks, (where is a good vac line to test vacuum with a boost gauge, this engine is really different to mazda and nissans)
    Can't afford a tune at the moment.
    Will change spark plugs soon, oil etc but I think the spark plugs are fine.
    The idle isnt erratic/hunting or anything, its like the TB is stuck open. Will have another look after TAFE tomorrow though
  1. 18R-C wont idle
    By dan_ta22 in forum Tech and Conversions
    Last Post: 26-04-2010, 03:00 PM
  2. 5sfe Idle Control Valve
    By ra_28 in forum Tech and Conversions
    Last Post: 17-09-2009, 01:05 PM
  3. 4AGZE fueling, idle and TB upgrades
    By Drifty Midship in forum Tech and Conversions
    Last Post: 06-03-2009, 01:27 AM
  4. haltech 4agze idle stability (big cams).
    By nb86 in forum Tech and Conversions
    Last Post: 01-12-2005, 03:30 PM
