do you mean having the injectors at the end of the trumpet and injecting the fuel into the trumpet?
Typically the longer the inlet tract modifies the torque curve. Hense the TVIS type system. The falcons also use a similar type system that opens longer runners in the RPM range to modify the torque curve.
I think that the internals that you will be running will suit your application fine. Have you thought bout balancing and blueprinting the engine? this could be a valuable step if you want to create a high revving atmo engine. The head is also quite an important part of an atmo engine and would be worth modifying
I havent done this setup myself, so i cant comment on how it will perform.
a decent dyno shop should be able to setup a map and tune the beast, best to ask and shop around tho!
