http://www.toymods.org.au/forums/showthread.php?t=30366 does this help, i can do a 300mm disc set up for the rear
Anything out there bolt on or that requires little fabrication to suit a 2wd yn45. Had a quick search but couldn't find anything!
GZE AW11, M40b18 e30, 1J cressida
does ya kit still allow for the h-brake to work?
yes you have to modify the cables, i can supply brackets, supply as a complete kit or drive in drive out
drive in drive out is what i like to hear.
pm price.
Hi, to do it properly, 2 new 300mm discs 2 recoed calipers new quality pads, all HT bolts and pipes modified to suit $550 cables can be easy or you have to have new ones made add $220 if you need new,cheers Rod PS you will need good front brakes to take advantage of this
