Results 1 to 8 of 8
Thread: identifying 2S bell-housing
    Default identifying 2S bell-housing
    quick query (i hope) - i have 3SGE block (gen1) and discovered that my random bell-housing fits it. Eye-lining it suggests the gearbox will be canted over slightly.
    It only has a '2' cast near the top where it bolts to the engine. Starter-motor & clutch slave attach on passenger side.
    Am I right to assume that this is a 2S housing?
    I was gifted it by blake (or wilbo?) many decades ago and had presumed it to be out of some commercial vehicle. Was seconds away from recycling it when packing up for the move to toowoomba.
    tia,
    charles.
    Melbourne Victoria
    Default Re: identifying 2S bell-housing
    the engine name or in this case the 1 st letter will be at the 1 oclock looking from the front to the imput shaft .could be G.T ,S and R series
    Hmm, pretty sure it wasn't me...
    I have a feeling it might be Y?
    That pic with the 2S and 3Y? markups me and Joel did up should be floating around somewhere? If you can't find it I'll have a look for my copy
    Wilbo's JZA80
    Wilbo's JZZ12
    Hi Wilbo!
    might have been blake then ... or maybe blake gifted it to you while your stuff was under our house? anyway
    i think i have that pic you're referring to ... or have come across it searching for 3SGE RWD conversion threads...
    found it (oddly enough in a folder titled 'bell') ... i also have a pic of my random belhousing:
    the number up the top:
    edit: your 3Y pic has the starter/clutch on the driver's side.
    looks like a 2S bell to me
    OGT-630 Grease Monkey rokusan's Avatar
    i vote 2s-c
    y series is half a hole out on the top bolt hole...if memory serves correct...
    SA63-3SGTE coupe driftpig
    Melbourne Victoria
    and starter and clutch is on the drivers side if it is a Y series
    thanks guys - 2S i can cope with - am not running a turbo on this motor.
    Now to find a suitable flywheel :-)
  1. Oil in bell housing....
    By shelldrake in forum Tech and Conversions
    Last Post: 11-11-2006, 11:22 AM
  2. oil in the bell housing, again
    By ae86 slide in forum Tech and Conversions
    Last Post: 28-12-2005, 08:02 PM
