Results 1 to 15 of 18
Thread: 1GGTE TA23 FUEL CUT ON BOOST! any one help?
    May 2009
    victoria
    Default 1GGTE TA23 FUEL CUT ON BOOST! any one help?
    hey guys ive been searching this forum but havnt had much luck i have a problem with my 1ggte its manual but with a A/T ecu i dont have a dash installed in yet.
    the car runs perfect doesnt miss a beat but as soon as i hit boost it fuel cuts straight away when i let go of the accelorator it goes back to normal i go to push it and as soon as its about to hit boost its fuel cuts all the time its like have a rev limiter or a speed cut. has anyone heard of this happening?
    any information will be greatful
    Aug 2009
    Default Re: 1GGTE TA23 FUEL CUT ON BOOST! any one help?
    is there an aftermarket fuel cut defender wired into the car somewhere?
    May 2009
    victoria
    Quote Originally Posted by pandaah View Post
    as far as i know everything is standard apart from the cooler,piping and exhasust..
    Aug 2009
    so it cuts as soon as say 3psi of boost is made, or does it try spike up past 12-14psi then cut?
    May 2009
    victoria
    it spewls but as soon as it come on boost bang cuts out...so i get no boost at all ..very strange
    Aug 2009
    hm, they shouldnt really hit boost cut unless for some reason your air flow meter is registering as maxed out?
    May 2009
    victoria
    so your thinking that my AFM is for the bin?
    Aug 2009
    possibly... unless anyone else has any ideas?
    Do you have a boost gauge hooked up to tell us exactly what boost it starts playing up on?
    RA23 - Twincharged
    JZZ20 - Daily
    May 2009
    victoria
    i think its because i dont have thge SP wire hooked up..i have a autometer dash made up ready to go in but i dont know how to hook the automneter guage to the the SP wire..i dont have a boost guage set uup but i know that i dont hit boost ill hook up the boost guage and see where it plays up.
    Its not something as obvious as a air leak or intercooler pipe leak is it?
    RA23 - Twincharged
    JZZ20 - Daily
    May 2009
    victoria
    nah ive check that also checked to see if my exhaust was breathing timing changed plugs ect..if the Sp wire is not connected will the ecu shut down?
    Iirc, sp is just for the speed sensor and not needed, but I could be mistaken. Will check wiring diags when I'm home next. As for fuel cut, the only thin I know that will do that is the afm signal exceeding the max airflow that the ecu will allow... although things like a faulty tps, or missing ground on a sensor can lead the ecu to kill fuel completely.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Aug 2009
    How do you adjust the afm if possible?
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    May 2009
    victoria
    ok ill change the afm and see how ill go thanks guys.
  1. a GOOD electronic boost control
    By renxun in forum Tech and Conversions
    Last Post: 27-01-2009, 02:54 AM
  2. more boost on 1ggte!
    By rollsy in forum Tech and Conversions
    Last Post: 27-03-2008, 02:46 PM
  3. Turbos 101
  4. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  5. 1GGTE 12 pound boost problem ? i need some help !
    Last Post: 29-12-2005, 09:12 PM
