Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: MX83 tacho modification
    Default MX83 tacho modification
    So i have a series 2 mx83 with a 1j and a link ecu (Vipec).
    I've searched and i know i can do a tacho booster and i know ray hall has a diagram for a tacho booster on the Vipec site but i want to actually modify the factory tacho to accept the signal sent from the link. I know this can be done as i have the PDF for the AE86 tacho conversion but the problem is i am not much of a electronics wizz.
    So i am after someone who is willing to shed some light on the situation. I can do the mods myself but i just need a bit of direction as to what needs to be done.
    I've added all the pics i can get to make it easy.
    Front of tacho board
    Back of tacho board
    I have also added the AE86 tacho mod as a pdf. This was hard enough to find on it's own.
    Cheers in advance.
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    Junior Member Grease Monkey Maverick's Avatar
    N.S.W.
    Default Re: MX83 taco modification
    This ought to make it better:
    Title now fixed. Cheers
    Default Re: MX83 tacho modification
    Want to update the thread with what fixed it?
    Sorry, Meant that the title had been updated.
    Ahh ok,
    Any idea what type of signal the link is sending out?
    Jan 2009
    sa
    gaugeworks on port rd in adelaide do this modification, i had it done to my dash.
    give them a ring maybe?
    I don't really want to be sending the dash away. I know i can do it myself, i just need an electronics guru for a bit of advice.
    This is from LINK.
    An auxiliary output configured as 'Tacho' produces a 0-12V pulse to drive a low-level tachometer. There will be one output pulse for each time a cylinder reaches TDC. Connect an Auxiliary Output directly to a low-level tachometer.
    G4 ECUs will NOT drive a high-level tachometer. High-level tachometers must be triggered by a coil’s negative terminal. Using a high-level tachometer on a multi-coil engine presents some problems, as each coil is not firing as often as a distributor engine’s coil would. In this case the preferred solution is to modify the high-level tachometer to accept a low-level signal.
    in Wilbo's thread here: http://www.toymods.org.au/forums/sho....php?p=1165293 the resistor on the signal line is bypassed/lowered. I can't quite make out the pcb tracks in your pic so I'll pull apart my spare cluster to see if it has a similar resistor inline. My car's not running yet so wont be able to test it myself for a couple of weeks.
    I put together that PDF in the original post when I needed to make my AE71 tach work with a 4agze ECU, I did a similar thing to my GX70 tach to make it work with a vvti 1JZ ecu also.
    Works also for the RA65 tacho and a 2JZGE
    Cheers JP. I thought i remembered something about you and that PDF.
    I need to trace out the MX83 board properly and figure out what the vertical black 750611-650 component does, I suspect it might be similar to what the resistors and caps do on the input of the older tach driver boards.
    Wilbo did an overlay of some new pics I took to make it easier to view what-goes-where, and for reference here's a schematic from one of the guys in japan who traced out a GX70G tach driver board:
    http://masa-ya.jp/index.php?plugin=r...ho.png&thumb=1
    Overlay: http://www.purcellperformance.com/uploads/overlay.jpg
    Cheers JP. You are a godsend. Are you going to be doing the same with your's?
    yep, I hate external boosters.
    Yeah i'm the same. I wan't to keep stuff to a minimum. I hate seeing cars full of crap they don't need. I have been watching your build and i must say, i'm very impressed with your work. Thing is though, it makes me feel bad that i have not updated mine.
  1. JZX100 V's MX83 auto Q's
    By TTMX83 in forum Tech and Conversions
    Last Post: 31-01-2011, 09:42 PM
  2. 1jz Jzx81 -> Mx83 Abs
    By mamba in forum Tech and Conversions
    Last Post: 21-11-2007, 08:28 PM
