Results 16 to 30 of 34
Thread: High tensile bolts for flywheel?
    Default Re: High tensile bolts for flywheel?
    Picked up some 12.9 cap heads. Same fit in the flywheel as OEM. Flywheel is 'hub' centric on the crank so i'm happy enough that it's all kosha
    Penrith BC
    same as what im running
    ../delete/ban
    tech moderator
    Quote Originally Posted by ed_jza80 View Post
    Well if they are good for 10k rpm they are good enough for the girlie revs i'll be running
    Stainless steel or high tensile steel?
    SS gradings are different to HT gradings.
    It's not SS
    Ah, so just plain black HT, will be fine then. Saw a flywheel come apart because the guy wanted the bling of SS.
    Just give them a touch of oil under the head for the right torque, and perhaps some HT washers to spread the load.
    what are thoughts on lockplates? loctite?
    Penrith BC
    1uz has an open thread on the deep crank side of the threads, so you 'need' some kind of sealant unless you want oil weeping out. i usually just run a med loctite thread lock.
    also agree with HT washers, i also run them in mine
    ../delete/ban
    tech moderator
    I always run loctite....haven't bothered with washers as flywheel is 15mm thick so no load issues
    Still will be a loaded step where the head of the bolt is. Bolt head is only 14mm OD at most.
    Quote Originally Posted by takai View Post
    So? All it does is hold it to the crank face and friction does most of the work. What's going to fail? Not the bolt head and nor the flywheel
    Penrith BC
    spreads the clamping load out, reduces the stress in the flywheel material right under the caphead. youll feel the difference when you torque it
    ../delete/ban
    tech moderator
    I know what a washer does, duh
    But in this case i don't think it's an issue? No washer with OEM and head surface area is similar enough. A few localised points of stress in that close grouping in that thickness material is a moot issue i reckon.
    sure, but i cat rattle of a bunch of OEM engines that ive seen where the shanked portion of the bolt ends whislt still inside the thickness of the flywheel. shanked portion locates the flywheel more precisely, but does not also engage the crank. simple torque of the bolts uses the friction between crank and flywheel to reduce shear load on the bolts.
    yeah that's no problem, I am talking about if the start of the thread on the bolt in in line with where the flywheel touches the crank, having the thread shorter or longer is ok.
    Tallahassee, FL USofA
    Yeah, they does like this.
    4AG stock & ARP.
    Thanks Club4AG!
  1. My high compression + boost concept
    Last Post: 18-06-2012, 09:40 PM
  2. 1ggte head bolts problem
    By elbak67 in forum Tech and Conversions
    Last Post: 29-11-2009, 03:50 PM
  3. Newbie Question - Gearbox bolts, where from?
    By ToNkA in forum Tech and Conversions
    Last Post: 12-09-2008, 07:36 AM
  4. RA65 High Beam Switch?
    By Hibino in forum Tech and Conversions
    Last Post: 01-01-2007, 02:10 PM
