Results 1 to 7 of 7
Thread: 7m sipgot bearing size??
    Penrith BC
    Default 7m sipgot bearing size??
    heya peeps
    just after the size of the spigot bearing in a 7m. dont really need a part number, just the ID/OD and depth of the bearing... need to see if we can get a bearing to accommodate a 19mm input shaft spigot in there!
    ed
    ../delete/ban
    tech moderator
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    Default Re: 7m sipgot bearing size??
    #6201-2RS
    OD:32mm
    Thick:10mm
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    Penrith BC
    thanks
    ed.
    ../delete/ban
    tech moderator
    19mm input shaft!? WTF are you using Ed?
    Penrith BC
    quaife 6sp sexquential. only comes with input shaft for a viper
    might need to grind it down to 15mm and use that bearing you dug out for the t56
    ../delete/ban
    tech moderator
    Ahh, fair enough. Thought it would be that, 19mm is HUGE though
    Aug 2006
    ed, try callling a bearing place and giving them the dimensions. may just get lucky
    EDIT: just gone through all the catalogues i have/can find (out of curiosity) and there is nothing particularly close available...
    linky if anyone wants one http://www.vxb.com/page/bearings/CTGY/17mm
  1. How to clean inside a motor that has eaten a bearing?
    By andrew_mx83 in forum Tech and Conversions
    Last Post: 05-01-2010, 03:07 PM
  2. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  3. Corona MK11 wheel bearing size???
    Last Post: 06-03-2006, 10:34 AM
