A lot of turbo cars use stock standard N/A spec cams, and a lot of normal cars use about 240 degrees duration. Maybe the 20valve has 250 degrees stock, can't remember.
Maybe for a wild turbo setup you can use a "mild" longer duration cam, like maybe 265 degrees. Use a adjustable cam gears. You would set it up with less overlap than on a N/A setup.
