Results 16 to 26 of 26
Thread: Fixing a hole in TB butterfly
    Tallahassee, FL USofA
    Default Re: Fixing a hole in TB butterfly
    Solder it, epoxy it, whatever it, a small bevel on each side will make sure it stays in place.
    Don't remove the plate from the shaft unless the screws can be removed & replaced without damage. Take your time adjusting its position before you finally tighten it to the throttle shaft, let it snap shut without binding in the bore when the screws are partially tightened.
    What if it doesn't run any better, but worse?
    What throttle body is it?
    Chiba
    Can I ask what you've done to the down pipe to the supercharger to make it fit?
    Also, braze is what I'd be doing.
    If you are using MAP gas go on buy a stick of PHOS COPPER. It is 100%better than solder as it is not brittle, bonds exceptionately well to brass and will fuse with the heat from your map gas torch.
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    北海度
    theres an adapter/reducer turned up from a block of alu joins the tb and j-pipe.
    i got the tb, adapter and j pipe all as one assy and havent had it apart cause i didnt wanna re-seal it.
    reduces back to the diam of factory j-pipe inside as far as i can see nothing else done.
    the aw11 it came off was making 125rwkw but he wanted his idle control back.
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Quote Originally Posted by oldcorollas View Post
    LOL at weld....
    milled? they are cut from sheet...
    back from holiday eh ed? or is it school holidays?
    Brazing isnt a form of welding now? I must have missed the memo.
    I actually am on holidays. Thanks for caring.
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    Welding takes the metals being joined beyond their melting point, brazing does not.
    May 2006
    Which one is braze welding?
    Quote Originally Posted by big_zop View Post
    ^This. Brazing is more akin to soldering than welding, you heat up a filler to just past liquidus and then it gets "sucked" ever so slightly into the parts to be joined (wetting), and then cools into a solid joint. Welding melts the filler and the parts to be joined, mixes them all together (coalescence), and then solidifies into one solid blob.
    Quote Originally Posted by Mr Ed View Post
    Braze welding is still brazing. The base parts don't reach melting temperature.
    May 2006
    Fair enough. Due to incorrect terminology, my suggestion was therefore completely wrong and the OP should definitely put a bolt/rivet through his throttle butterfly instead.
    random definition
    Brazing is a process for joining similar or dissimilar metals using a filler metal that typically includes a base of copper combined with silver, nickel, zinc or phosphorus. Brazing covers a temperature range of 900ºF - 2200ºF (470ºC - 1190ºC). Brazing differs from welding in that brazing does not melt the base metals, therefore brazing temperatures are lower than the melting points of the base metals. For the same reason, brazing is a superior choice in joining dissimilar metals
    that Phos copper stuff is sort of half and half.. the phosphorus (and boron in some braze materials) can diffuse quickly into the substrates and lower their melting points temporarily (until the P or B diffuses away).
    the phos copper melting point is not so low tho.. (dependign on alloy)http://www.uniweld.com/catalog/alloy...hos_copper.htm
    this is called "transient liquid phase bonding" (TLP) and is halfway between brazing and welding...
    so you have, in order of temp
    solder (tin/lead or lead free base ~250-350C?)
    silver solder (high temp soldering ~400-500C?)
    silver/phos copper/etc braze (low temp brazing (500-700C?)
    brazing..
    etc etc
    welding...
    edit: ona similar note, plastic welding is weldign cos the base materials also melt.. dunno if there is plastic brazing
    By The Witzl in forum FAQ
  2. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  3. how to isolate the gearstick hole in RWD engine conversions
    By kewp in forum Tech and Conversions
    Last Post: 01-12-2009, 03:17 PM
  4. Best way to fix stuffed aluminium threaded sensor hole
    Last Post: 31-10-2009, 08:43 AM
  5. Fixing hole in car floor
    By wagonist in forum Tech and Conversions
    Last Post: 10-11-2007, 11:48 PM
