Results 1 to 7 of 7
Thread: Bypassing ISCV cause high vacuum?
    Default Bypassing ISCV cause high vacuum?
    Hi guys,
    Just a quick question. I have disabled the ISCV on my 3s-gte and have just adjusted the throttle plate so it can idle.
    I'm only getting like 12in/mg of vacuum @ idle (from my research I think I should have from 18-22) and was just wondering if this would be caused by having that throttle plate cracked open just a bit? Or should I be looking for a vacuum leak?
    AE93 GTi - 3s-gte
    Default Re: Bypassing ISCV cause high vacuum?
    id be looking for a leak
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Also worth while to check your cam timing and valve clearances.
    Cam timing and valve clearance should be ok as the motor was just rebuilt and new belt was put on.
    Machine shop took care of the valve clearances
    AE93 GTi - 3s-gte
    if it is idling at the same speed, then the manifold vacuum will be the same.. regardless of how the air is leaked in (throttle plate or ISCV)
    look elsewhere.
    btw, why would you disable the ISCV? you want to have to manually control the idle?
    Quote Originally Posted by obrim View Post
    Yeah a mate had an engine built by a well known engine builder, but they still had cam timing out buy some ridiculous amount, 4+ teeth (can't remember exactly) .
    A simple double check eliminates 1 possibility with ease.
    ISCV was bypassed because its faulty.
    And I did the timing belt myself Check it like 5 times.
    I'm going to start looking for a vacuum leak me thinks.
    AE93 GTi - 3s-gte
  1. Crankcase Vacuum Regulator Location.
    By Duk in forum Tech and Conversions
    Last Post: 23-06-2010, 02:02 PM
  2. ISCV Cleaning (*May* solve poor/erratic idle)
    Last Post: 31-08-2009, 12:57 PM
  3. 7MGTE ISCV circuit on ECU board?
    Last Post: 11-05-2007, 04:44 PM
  4. 7MGTE ISCV Dilemma
    Last Post: 05-10-2006, 07:19 PM
  5. Replies: 9
    Last Post: 21-03-2006, 10:41 AM
