Results 1 to 15 of 17
Thread: Twin Turbo setup - How to know if one is jammed
    Selangor
    Default Twin Turbo setup - How to know if one is jammed
    I was searching out this info, couldn't find any clues. What happens when one turbo on a twin setup, 1JZ or 1G-GTE fails,not spin etc.
    What are the symptoms ? OR if the problems is just starting what are the signs to look for ?
    Thanks
    Dispatcher
    Aug 2009
    Default Re: Twin Turbo setup - How to know if one is jammed
    Also keen to see some replies, tried to do a search but couldn't find much.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    I would think that if one was completely jammed then you would notice a drastic loss in power... It would be very tough not to notice I imagine the odds of it completely seizing are pretty minimal anyway
    More likely with these is oil seals going, which will show itself as smoke under power, or in my case a buildup of smoke at idle as well
    Aug 2009
    Well my car doesn't seem all that powerful, but I don't know how well a 1ggte goes stock in an ra65. Might have to dyno it.
    What gen is your 1g Blair, if stock and gen3 running stock boost with a stock dump pipe (restrictive) you will be around 120-130rwkw.
    RA23 - Twincharged
    JZZ20 - Daily
    Apr 2007
    The Maximum boost developed would be well down on normal levels & also the boost what there is would come on quite a bit later through the whole range as its only pumping half the volume of air..
    But as has been mentioned i'm sure there would be other issues too ..
    Kedders, do you think it could be that high ? i have seen some stocky 1JZ GTE's with not a real lot more than that ..
    Check the 1ggte dyno thread mate, lots of stock dyno figures around that figure. Remember gen3's run 11psi.
    With a set of dump pipes I was making 140rwkw on my 1ggte, stock boost + stock turbos.
    RA23 - Twincharged
    JZZ20 - Daily
    I'm not a fan of thinking of symptoms to diagnose problems, but I would guess the working one would run hotter than the non working one.
    You could try forcing open the wastegates one at a time and seeing if it makes any difference, or fitting a pressure tap before each turbo and seeing if they are pulling the same vacuum on boost.
    Can you get the inlets off easily?
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    On 1JZ / 1G style twin turbo setups, where the turbos are in parallel and share a common intake if you have one turbo 'Jammed' then you will not make any significant boost.
    All the air pressure that your working turbo tries to generate will go back out to atmosphere via the 'jammed' turbos compressor side as this is a much less restrictive path than going into the engine
    Your working turbo won't be able to work as intended
    I hope this makes sense for the full failure.
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2007
    Do you have boost pressure guage? If not then get one that way you know if its producing proper boost. Then go looking for problems. Are you hearing any noises ?
    May 2007
    Quote Originally Posted by wilbo666 View Post
    this man speaks the truth... my rear turbo of a 1jz had a snapped shaft and the rear wheel was lodged into the rear housing of the turbo... strange thing was from the front wheel it felt quite normal and spun freely etc... also didnt blow any smoke etc
    the result was no boost and the car struggled to build revs as there was a major restriction in the exhaust housing ie the non spinning turbo wheel...
    Selangor
    Thank you all very much, I will keep this info handy.
    My 1JZ is still making decent boost. But there's some whistling (or whining) that comes on on start and sometimes on acceleration.
    Dom
    May 2007
    Quote Originally Posted by Dispatcher View Post
    Dom
    It could be loose intercooler hose. Worse case turbos wearing out
    Aug 2009
    mines a gen2 1ggte.
    I also get that whining/whistle sometimes when coming on boost.
    Gen2 will be around 100kw at the wheels, stock boost.
    RA23 - Twincharged
    JZZ20 - Daily
  1. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 11:06 AM
  2. mr2 corvet 1UZ twin turbo or 2JZ-GTTE
    By bje10s in forum Tech and Conversions
    Last Post: 09-06-2007, 04:26 PM
