Results 1 to 7 of 7
Thread: 4AG 20V Head Bolts
    Junior Member Domestic Engineer psychofox's Avatar
    Default 4AG 20V Head Bolts
    I've got a spare 4AG 20V lying around that I am pulling down to rebuild. I gt to the bit where I pull the head off and struck a problem. The head bolts seem to require a 12 point Allen key - which I don't have. I was wondering if anyone had the specs/size of the socket required to take the head bolts out? I've trawled the new and old forums but have had no success...
    Also, does anyone know if ARP do a Head Stud kit for the 20V - I have heard you can use the 10 of the long studs from a 16V it, but that doubles the cost....
    Thanks in Advance.
    Fletcher
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    Default Re: 4AG 20V Head Bolts
    On a 16v head you need a deep 10mm double hex socket
    20vs are diferent to 16v, go to your local tool shop and they shoud be able to sell you the right socket, think mine was $10 from total tools brookvale.
    Quote Originally Posted by cri_ag
    Yeah 20V is different to 16V. What I'm after is what size it is, I don't want to have to go back and forth from a tool shop to work out what it is....
    And obviously I can't take the bolt there and say "I want that one" Little Britan Style.
    Current Cars:
    S.A
    hey psycho lol. Sounds funny
    Is it deff a 12 point hole in the head of the hole??????? if it is i have your fix!!
    Im betting it a 10mm 12 point allen ( torx ) bit you need.
    What you do is get a bolt with a 10mm 6 point head turn it upside down and see if the head of the bolt fits snug into your 4a head bolt ( follow me ) this will give you an indication of size then you can go buy correct size allen bit!!
    the size is def. 10mm, i've just taken off a 20v head, with your average 10mm allen key (6 point) and the bar from an engine hoist used as lever. they are def multi point but only worked that out after cleaning the gunk away when head was off.
    New Zealand
    they are not a torx bit.... torx will round them off
    theres a good post on toyspeed (which is down today) about it
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. 4ag head question
    By bmak in forum Tech and Conversions
    Last Post: 27-02-2006, 10:03 PM
  3. 2T-G head bolts or studs - availability?
    By SeptemberSquall in forum Tech and Conversions
    Last Post: 19-12-2005, 10:13 PM
