Results 1 to 11 of 11
Thread: RWD 4age PS Setup???
    Backyard Corolla Kid Grease Monkey
    Default RWD 4age PS Setup???
    Hi all,
    i picked up an AE70 hardtop coupe recently, and im currently performing a 4age conversion on it, but i have run into a few technical difficulties...
    the car has Power Steering, and i want to retain the PS, so im wondering if anyone here has/is running a RWD 4age with PS?
    and if so, what parts did you use? im aware that i will probably need to re-run the lines
    the motor im using is a FWD bigport 4age
    thanks
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default Re: RWD 4age PS Setup???
    Most of the AE86 Apex models have power steering. So you can get it all working with factory parts. Lots of people should have the P/S pumps and brackets left over from their import motors.
    yeh i figured i could use all the JDM gear, but i dont really want to have to spend the extra money on the rwd alternator and water setup
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    If it is the setup that I think it is could you just use the A/C compressor as an idler and run the belt as per normal?
    Alternatively I have eliminated the A/C and used a ribbed pulley for the tensioner and run the belt the other way around this pulley to tension the belt. Has not ever let me down this way.
    i'd try to adapt the PS pump off the 4AC onto the 4AGE, might take some doing but would be the easiest way to do it (no arsing around with plumbing)
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    Quote Originally Posted by newbien View Post
    I'm guessing that you're using all the fwd ancilleries on the motor. If that's the case, then why not use the PS pump and bracket that came on the AE82s?
    The throttle body has idle up functions for the PS and the aircon which sit on the same bracket. If you've already got the PS rack then you just make up the lines and away you go.
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    yeh i was planning on using the FWD ancilleries, as i have them
    yeh ill probably go that route, only thing im thinking ill have problems with is the idle up gear...seeing i will getting the manifold cut and shut
    Vancouver, BC
    A cut and shut manifold won't affect your idle up gear as it attaches to the bottom of the TB. What it will affect is the PCV routing - ie. you'll need an oil catch can.
    no worries, not really up to par on engine stuff
    cheers for the info
    Vancouver, BC
    No problems.
    As a side note, the PS bracket is also the A/C compressor bracket if you want a bit of aircon action to keep you cool in summer. I spoke to an A/C guy a while back and he quoted roughly $500 to convert from R12 gas.
    yeh im not so fussed about aircon as im used to not having it, and im not out much during the day cheers for the heads up though
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 06:53 PM
  2. 4AGE carby dizzy setup
    By Grega in forum Tech and Conversions
    Last Post: 03-01-2008, 09:12 PM
