Results 1 to 7 of 7
Thread: Ecu pinout charts wanted: 1GEU + 1GGTE (gen3)
    Apr 2010
    nz
    Default Ecu pinout charts wanted: 1GEU + 1GGTE (gen3)
    Hey guys
    Im after the ecu plug layouts for both the 1geu and 1ggte (gen3) engines.
    Needing to wire up the tacho guage...
    Dec 2008
    Lancashire, UK
    Default Re: Ecu pinout charts wanted: 1GEU + 1GGTE (gen3)
    IS200TT.co.nr
    The Evolution of my 1GGTE Turbo Lexus
    Please leave your comments.
    Tacho on the 1GEU comes from the negative side of the coil.
    Tacho on the 1GGTE comes from the IG- wire on the ignitor (same as the IG- wire in the diagnostics box).
    Neither come from the ECU.
    You'll need a booster to get the original tacho to work with the 1GGTE ignitor as well.
    Apr 2010
    nz
    So do i need to connect the dash loom tacho wire to the ignitor. Can you please explain to be about the booster? Is the booster covered here? http://www.toymods.org.au/forums/sho...ht=1ggte+tacho
    Seams reasonably simple...
    Yes, booster is covered there.
    The booster 'input' will be the IG- wire (this wire will also be on the ~20pin dash interface plug)
    The booster 'output' goes to the dash loom wire.
    Apr 2010
    nz
    So i could splice right into it then connect it to the tacho?
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Side note: Alot of Toyota ECUs have the pinouts written on the PCB. If you pop the cover off the ECU you can read them easily.
    This worked on my old 1G-GTE
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 08:10 AM
  2. 1GGTE TVIS + Aftermarket ECU and BB Turdbro
    By Kedderz in forum Tech and Conversions
    Last Post: 31-01-2009, 09:18 PM
  3. HELP: 1GGTE running slow, Error code 11.. what is it? *FIXED*
    By Jabtronic in forum Tech and Conversions
    Last Post: 31-01-2009, 02:05 PM
  4. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 01:42 PM
