Use your original top bearing girdles. When the head was made it will be line bored throught the cam bearing journals in the head so only the girdles fitted to that head will line up and they have to be kept in the same place. if you put bearing girdles from another head on your head you will need to have a bit machined off the bottom of the girdles and then get your head line bored through the cam journals.
