Results 1 to 8 of 8
Thread: What the? fuel pressure problems 1JZGTE
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    Default What the? fuel pressure problems 1JZGTE
    so i decided to give the supra a turn over assuming as she has been sitting there for nearly 2 weeks, not a happy chap to start in the cold, but starts none the less. moved her from the car port to the garage and left her to idle and warm up. when popped the bonnet i noticed the motor was running odd. had a look at the fuel pressure reg. WTF? never done that before..
    here is the vid of the reg. what could cause this?
    http://www.youtube.com/watch?v=xHUQUZkKl9E
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    Default Re: What the? fuel pressure problems 1JZGTE
    dodgey fuel pump? try a different gauge first
    Jan 2009
    sa
    check voltage to pump?
    either dodgy pump or dodgy FPR
    or dodgy gauge
    check the voltage at the pump to begin. the guage should be fine because you can hear the idle drop as the pressure falls away. if the voltage is fine i'd be checking the fpr. may have a damaged diaphragm. what kind of fpr is it and what type of pump?
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    If you remove the vac/pressure source to the FPR do you get the same effect?
    Wilbo's JZA80
    Wilbo's JZZ12
    Apr 2008
    Quote Originally Posted by mr1jz View Post
    its just a cheap FPR off ebay. fuel pump is a bosch..
    wilbo, what will i be expecting to see if i remove the vac line?
    BURN RUBBER
    Quote Originally Posted by BEVANI View Post
    Well it might tell you if it is related to manifold vac or not...
    Wilbo's JZA80
    Wilbo's JZZ12
  1. What is the factory fuel pressure for a 4agze?
    By cam_ra40 in forum Tech and Conversions
    Last Post: 20-04-2011, 05:42 PM
  2. Replies: 38
    Last Post: 02-06-2009, 01:55 AM
  3. Twin Carb fuel setup
    By soulfire in forum Tech and Conversions
    Last Post: 18-12-2008, 02:38 PM
  4. 3tc wont start please help
    By Cob604 in forum Tech and Conversions
    Last Post: 29-07-2008, 06:56 AM
  5. Replies: 1
