Results 1 to 10 of 10
Thread: Cooling setup for 4agte V-mount
    Nov 2009
    Default Cooling setup for 4agte V-mount
    Car - ke70
    motor - 4agte
    use - Cooling arrangement for header tank & turbo
    problem - dont know how to run cooling to turbo/header tank
    occurs/started when - when I put it together
    Details:
    Hey Guys,
    I've cut my car up, installed V-mount for the rice and epic drifto, booked the car into get the ECU wired/tuned up next week and I need to get the cooling system sorted out before it goes in.
    From all the googling I have done, it looks like most ppl run water to the turbo by tee 'ing off the heater lines. Not running a heater box so I'm hoping it is as easy as the diagram below.
    What I don't know if the line from the turbo to the header tank will flow enough to cool the turbo and not too much to create too much pressure and bye bye turbo. Or simply if what I am thinking is just completely wrong and there is a way better way to do it?
    Has anyone run a header tank on there 4agte and if so help please? Any advice would be great and photo's would be awesome too!
    If at first you do not succeed, get a hatchet and brake it
    Default Re: Cooling setup for 4agte V-mount
    you can run your turbo with-out running coolant through it. it wont be bye bye turbo.
    you may not be running a heater box anymore, but the outlet/inlet to the heater will still be on your engine, plumb them to your turbo.
    Coolant line that go to the throttle body are another good option.
    Nov 2009
    I was more concerned by the change in size from the 15mm heater lines to the 8m or so inlets on the header tank.
    I talked to one of the mechanical engineers from work and he said that there would be a small increase in flow velocity and a slight decrease in pressure, (as per venturi effect) but it would be very minimal due to the short length of the hoses. So that problem is solved.
    Yer feral4mr2 as per the the engine cooling system diagram, I am definitely using the rear water housing to supply water to the turbo, its right next to turbo, it seems like the easiest solution.
    So, after that the coolant flows from the Turbo to header tank and header tank empties into ae92 remote thermostat housing?
    Is this the best way to do it? Anyone done it before want to let us know how they did it?
    Junior Member Backyard Mechanic cri_ag's Avatar
    ive done it before, but im not entirely convinced with the results. the header tank made the car much more stable (temp) but it still has a fit at the track. temp will be fine, then start to rise, then the temp gauge rockets up, then down then up, till i back off and cruise around. very annoying.
    i tapped a fitting into the top of the water outlet for the back of the head, used the old throttle body water line and put the last bleed into the lower radiator pipe. however my turbo draws water from a fitting on the thermostat housing. will get a pic when i can get down to the garage
    4agte Sprinter - 11.7 @118mph WSID
    2.45 @ mount panorama
    1.56 @ eastern creek, 1.10 @ wakefield
    1.24 @ oran park GP
    2.00 @ Phillip Island
    i cannot see any reason why a header tank is needed???
    Tasmania
    need to have a point in the cooling system higher then the head, usually its the radiator, but in this case its v mount and is lower.
    1973 TA22
    Quote Originally Posted by cri_ag View Post
    sounds like the radiator and thermostat was overly doing it's job.. need a bit more flow through thermostat to keep it a bit more open, rather than opening and closing (and allowing hot water to flow thru until cold water hits thermostat again)
    Tallahassee, FL USofA
    Quote Originally Posted by n00bvak View Post
    It'd be nicer to get the coolant from the block rather then pre-heated from the head.
    Putting it into the header tank, bypassing the radiator, will cycle it back into the engine without being cooled down.
    The turbo shouldn't care much about pressure, just heat.
    Nov 2009
    as per the diagram and what I have said above, the header tank will empty into remote thermostat housing which returns to the radiator. Not to the head. That would kind of defeat the whole point if hot water is returning to the block.
  1. Mount Gambier Autofest & Show N Shine
    By les adams in forum South Australian Events
    Last Post: 14-08-2009, 05:13 PM
  2. Mount Gambier Autofest & Show N Shine
    Last Post: 02-11-2008, 08:54 PM
  3. mr2 rear engine mount issue
    By 4agte in forum Tech and Conversions
    Last Post: 06-07-2007, 06:23 PM
