Results 1 to 6 of 6
Thread: Cleaners For Spark Plugs
    Selangor
    Default Cleaners For Spark Plugs
    I don't have one of those motor-operated or sand-blasting
    type cleaners, so I have been using carburettor cleaner to
    flush out fouled spark plugs.
    I wonder if the carb cleaner may be corrosive to the
    ceramic insulator or other parts of the plug ?
    The number 2 and 3 plugs foul often due mosty to worn
    valve seals, so I take them out every now and then to
    clean them as a stop-gap measure.
    The circular gap between the lower ceramic insulator
    and the inside of the thread shell gets gummed up with
    carbon deposits, so I spray carb cleaner into there to
    try to loosen and flush them out, then try to dig out the
    remainder at the bottom as much as I can with a small
    allen key.
    The plugs were reusable after the first few flushings. However,
    after the last cleaning, they appeared to have intermittent
    misfiring.
    If carb cleaner is too strong, how about one of those multi-purpose
    cleaners like the WD40 and similar products, "dry" type electronic
    contact cleaners like those CRC products, Philips DCS390 contact
    cleaner/degreaser (below) or even engine degreasers ?
    http://www.sanace.com/Spray_Cleaners/pspray_dcs.html
    Thanks.
    perth
    Default Re: Cleaners For Spark Plugs
    carb cleaner will be fine, but its normal for fouled plugs not to come back.
    you could put some hotter plugs in to aid with the oil burnt fouled plugs, but ultimately you should fix your motor.
    Unfortunately scraping the carbon from the root of the insulator is probably scratching the ceramic surface, leading to a loss of insulation. Check your spark plug catalogue at the parts shop, and go up a couple of heat ranges.
    cheers Chuck.
    MS51Crown Coupe,
    Selangor
    Thank you for all the good info.
    Yes, I believe that scraping the carbon at the root of
    the ceramic insulator would be scratching it and cause
    a loss of insulation, which may well tend to make it misfire.
    And I understand it is also unlikely for a fouled plug to
    be properly cleaned and revived back to new.
    I am already using NGK BP5ES, and I think the hottest
    is BP4ES. Unfortunately, Malaysia has a poor selection
    of spark plugs on the market. The motorists nor the parts
    shops here don't seem to know what hot or cold plugs are.
    The only ones they have been selling here over the past
    20 years or 30 years are BP5ES and BP6ES. Same for
    Nippondenso, only W16EX-U and W20EX-U are available.
    Bosch too, just W8DC and W7DC.
    I guess I will have to replace the valve seals sooner or later.
    sooner rather than later?
    or swap plugs every 2nd cleaning...
    Selangor
    I took out the plugs yesterday and cleaned them
    with CRC contact cleaner this time.
    http://www.crcind.com.au/catalogue.n...r?openDocument
    This appeared to be more effective than carb cleaner
    and the engine seemed to idle better and run smoother
    after that.
    However, I couldn't see any loose carbon or sludge draining
    out from the insulator root. I wonder where it all went. In fact,
    nothing seemed to drain out, it's that quick-drying.
    Electronic contact cleaners don't usually leave any residue.
    The outside of the thread shell felt cold after that, wonder if
    they use liquid nitrogen or something.
    Can I swap the fouled Number 2 and 3 plugs with Bosch W8DC,
    and mix them with the NGK BP5ES on number 1 and 2 cylinders,
    next time around ?
    The Bosch plugs seem to be a bit less subsceptible to fouling.
  1. 3SGTE injector plugs
    By Invid in forum Tech and Conversions
    Last Post: 21-04-2009, 08:36 PM
  2. please help everyone...1jzgte wiring loom plugs?
    By hu5tln in forum Tech and Conversions
    Last Post: 09-10-2008, 06:29 AM
  3. Lowered compression=hotter plugs?
    By tooch in forum Tech and Conversions
    Last Post: 20-07-2006, 06:22 PM
  4. 7MGE injector plugs same as 7mgte plugs?
    Last Post: 23-04-2006, 01:28 PM
