Results 1 to 6 of 6
Thread: 2TC 3TC Carburettor and Fuel Pump Lines
    Nov 2007
    Tasmania
    Default 2TC 3TC Carburettor and Fuel Pump Lines
    Does anyone know the fuel connections for a 2T/3T fuel pump and carburettor?
    The inlet for the carburettor.
    The inlet and outlet of the fuel pump
    I've labeled the connections:
    Melbourne, Victoria
    Default Re: 2TC 3TC Carburettor and Fuel Pump Lines
    ..try this....it should hopefully explain
    http://www.toymods.org.au/forums/sho...ber+connection
    - Jackie Stewart
    Nov 2007
    Tasmania
    The fuel pump pictured above has got three pipes.
    So, pipe No. 3 is connected to fuel tank -> fuel filter line?
    Pipe No. 1 goes to connection B?
    Then from connection A to pipe 2 (the return line)?
    i could be wrong but i think the fuel pump u have there is for a carby without a return line on it, as the fuel pump has one on it.
    ill have a look at how mine was setup and see.
    dan.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Nov 2007
    Tasmania
    OK, that will be great.
    I just had a look at your rides thread, and it looks like your fuel pump only has two connections:
    http://www.toymods.org.au/forums/sho...?t=6516&page=4
    Mines a 13T block so I guess the pumps/carby could be slightly different.
    yep mine had the return on the craby, the other one looks like it had none, thus would of used the return on the fuel pump.
    hope this helps a little
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
