Results 1 to 12 of 12
Thread: Help needed about 1J
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Dec 2006
    Default Help needed about 1J
    Ohk lads get to point,
    Just helped finished wiring up a mates rig and the car won't fire up.
    Got power to igniter, coils, injectors AND fuel pump and still won't fire up. BUT the fuel pump sounds very quiet (stock) can barely hear it, are they suppose to have a loud wizzling sound? Have checked fuel return line also and fuel is only pumping out quite slow? normal? or are they suppose to pump out like when you had a carton of beer??
    My point is, is the fuel pump being gheyy? or is the fuel pump not getting enough voltage to it? or is it something else?
    Also i will end up wiring the fuel pump with the two rely with FPC where someone posted on here. At the moment the fuel pump is wired to B+ constant power.
    Any help much appreciated.
    Heng
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Aug 2009
    Default Re: Help needed about 1J
    have you checked fuel pressure?.. injector pulse?.. the motor hasnt been sitting out of the car for too long and clocked up the injectors has it?
    Dec 2006
    how do i check fuel pressure with out a gauge? Dont think it be injector pulse but will check it.
    Aug 2009
    you cant check without a gauge.. but if you take the inlet line off and put it into a 2ltr bottle or container and it pisses out then its pritty safe to say its got fuel going up to the engine, then its down to spark at the plug, compression and timing
    When you say stock pump, stock for what?
    My 1J cressida came with a fkn loud GTR pump in it (that was probably dying) - i swapped it to a walbro, and now i have to strain to hear it.. So while its obviously apples and oranges, surely a stock pump wouldn't be louder?
    Dec 2006
    A Cressida!
    I think i will have to wire up the fuel pump properly and see if that will solve the problem.. If not then i im just gonna set the thing on fire. Will double check everything else too.
    Will do it this weekend.
    Hengsta, first step, would be to replace the fuel filter.
    cheers Chuck.
    MS51Crown Coupe,
    Dec 2006
    Brand new fuel filter on there.
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    if its cranking over then try running the fuel pump off a relay thats switched on ign. +12v batt (30), ign +12v (85), ground (86) and fuel pump (87). fuel pump wire is on the sqaure grey body plug on the cressida its a thicker wire, blue with a red stripe normally on the bottom left corner if your looking from the back of it (not the back of the male engine loom plug). If it still doesn't work then you have most likely eliminated the fuel as being a problem. I wouldn't recommend this to be the permenent solution to switching the fuel pump. But at least you know its working.
    Jun 2009
    hi mate
    i just finished wiring my cressida and have it running, in terms of fuel wiring, i ended up bridging the fuel pump resistor wires which sits on the drivers side strut tower and connected the FPR wire on the 1jz loom to the 22pin mx83 FPR wire. Mine started first kick no probs at all
    small vid of mine
    http://img80.imageshack.us/img80/6294/p7020001.mp4
    Any question feel free to ask
    Andrew
    Dec 2006
    Dave: I thought about doing it that why too but since its a mates car i like things done properly lol. Still havnt had a chance to look at it over this weekend.
    rxfc3s: Never thought about brigding that risistor pack but i did hear it some where when i was wiring my old 1j z20. Will give that a go though for sure.
    Cheers for the help lads
    This will def help others out also with fuel pump wiring trouble, also will help me out when i come to wire up my 2j to the cressy.
    Feb 2008
    you could do it a simular way with the oil pressure switch light instead to trigger the relay.
  1. Manual Gearbox Needed
    By mark2 in forum Tech and Conversions
    Last Post: 26-03-2008, 01:46 AM
  2. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 12:15 PM
