Results 1 to 10 of 10
Thread: 3sgte sounds like wrx..?
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Default 3sgte sounds like wrx..?
    hey, was running perfect..AGAIN! than i turned it off, realised there was a huge pool of oil, re thread taped the oil pressure sender, (as i thought this was the cause as the pool was were i had worked on it last, than put everything back together and started it, it idles and starts but sounds liek a wrx, i inspected cap and rotor, and all are ok...=(
    Default Re: 3sgte sounds like wrx..?
    Congrats You have found one of the limited edition wrx 3sgte's!
    *should be running on 3 cylinders
    based on experience from a mate's honda civic, WRX sound = blown head gasket.
    to check it its running on 3 pull the plug leads one at a time.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Apr 2008
    yeah thats what i thought..but was running fine when i turned it off why would it die instantyl on start up?? pulled no.1 off and the idle went rougher..try with all 3 left?
    When you pull the correct lead off with the misfiring the sound wont change.
    Apr 2008
    mmk all good now, not sure what it was, but did the lead test and now all good, theres smoke coming from the exhaust join near the centre of the turbo, i know the turbo is fair dead but didnt know smoke would come from it?
    Severely Underqualified Domestic Engineer Fodder's Avatar
    Motor also sounds pretty different with the AFM unplugged - maybe a loose connection there or something?
    Apr 2008
    nah AFM plug all good, stalls with it off =p but the smoking from the inner of the turbo?? i just noticed that only under boost its letting loose lots of smoke, i dont reckon it degraded heaps quickly i.e over night, but i changed the oil to magnatec, lower viscosity, i reckon the turbo is showing its true dead colours
    Apr 2008
    Do i get a prize? =) hopefully a new gt28 perhaps?
    Quote Originally Posted by roadsailing View Post
    same, but blown HG between cylinders.
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 11:33 PM
  2. Replies: 22
    Last Post: 13-11-2009, 03:10 PM
  3. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 04:03 PM
