only a problem if it causes hesitation.
on MS you can tune the enrichment on throttle movement in diffrent parts of the map to eliminate the hesitations, or, you can richen up those areas which are onyl ever used in the transition.
but if it still smooth, the lean AFR will not usually cause issues
