Results 1 to 4 of 4
Thread: a42de vs a340e
    Apr 2009
    vic
    Default a42de vs a340e
    Hey guys,
    This is the first time Ive had to post here for help, because normally its been covered before...
    I have gz20 soarer...
    Not a 1g-gte or even a 1g-ge, but a 1g-e...
    Anyway, It has a blown trans....
    Its missing the build plate, so without knowing any better, I got an a340e...
    But it turns out it has an A42DE....
    All I can find out is this came in z10's aswell, but not much more...
    So before I start something I cant finish,
    Does anyone know if they be swapped or do I need an a42de...?
    What other cars came with this trans, and are they hard to come by ? (apart from z10s)
    I would assume mk2 supras?
    Im not too keen on doing anything much with this, apart from being a daily...
    Im not interested in a manual swap at the moment but If costs are too high Id rather sell it , part it or convert it at a much later date, as I already have other projects...
    Thanks guys
    Tasmania
    Default Re: a42de vs a340e
    MX 73 Cressi runs the same auto.
    Cheers Brett.
    Nov 2007
    Might be able to use A340E, but to be on the safe side get the a340e bell and torque converter, also tailshaft might be different.. Also may have to re-use A42DE's speed sensor gear to get correct reading,
    Easier to just find a replacement a42de
    Apr 2009
    vic
    Thanks guys, I have worked it out now....
    Ill just put a 7m with the a340e and the 1g-e and a42de are going here:
  1. JZX81 A340E vs MX83 A340E
    By Hibba in forum Tech and Conversions
    Last Post: 26-01-2007, 01:12 AM
  2. MZ20 A340E behind 1jz VVTI?
    By JZA20 in forum Tech and Conversions
    Last Post: 24-07-2006, 07:22 PM
