Results 1 to 15 of 26
Thread: CT12A turbo reconditioning jzz30 soarer
    south australia
    Default CT12A turbo reconditioning jzz30 soarer
    Hi guys,
    after getting the howling banshee sound and checking all pipes were secured, I ended up removing the turbos.
    Now that i have them sitting next to me, i can't determine what i am looking for what is wrong with them.
    I can spin the shaft on both sides of the turbo freely, there is a bit of lateral movement on both, roughly the same there is no front to back movement on either, and i can't see any signs of the turbines hitting the casings either. but that's about as far as my knowledge extends.
    I had purchased a second hand replacement set some time ago, and honestly, now that i have pulled off the current ones, the second hand ones seem to be roughly the same condition in terms of shaft play. As such i am a bit reluctant to use the second hand set to replace with if they are in a similar condition.
    Is there anything else i can do to verify the condition of these turbos or is it off to a professional time?
    If it is professional time, is there a reputable person in Adelaide that might be able to have a look at these to see how bad they really are or aren't before I put them back on the car?
    Barnsey
    Aug 2009
    Default Re: CT12A turbo reconditioning jzz30 soarer
    are you possitive the noise was coming from the turbos?..
    south australia
    not 100% but things started to scream at around 2000RPM or as soon as I accelerated. ie. going up a hill, taking off from lights etc.
    it wouldn't do it free revving.
    Aug 2009
    describe scream.... motors dont scream lol
    Nov 2007
    turbo starved of oil?
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    you sure its not the turbos spooling up that you can hear? mine does that noise but ive got a rear turbo exhaust oil seal is screwed!
    1992 - JZA70 STOCK - SOLD
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    Check the condition of your serpentine belt, if it is warn it will scream "replace me master".
    south australia
    the scream could be described as a child that had been smoking since birth and has emphysema doing one of those annoying high pitch squeals that they do when they want attention....just as i go to accelerate.
    serpentine belt was replaced 40K ago and still appears to look fine.
    there looked to be a good amount of oil in the turbos and the pipes all looked to be clear, they are still attached to the block so i will take them off and blow through them to see if there is a blockage where I can't see.
    the sound sounds like it should be the turbos spooling up but instead of sounding like it is spooling, it sounds like it is approaching critical mass ready to explode (i didn't check this by the way as I tried to keep the revs down until I was able to pull them apart and have a look knowing i had a spare second set...which turn out to look to be in the same condition as the ons I pulled off)
    Jan 2009
    sa
    you really cannot tell the condition of them until you take them apart and look at the bearings and seals, and the wear on the shaft.
    i just had a set i have rebuilt, as the current ones on my car blowing alot of smoke and screaming, (pretty much the same noise as yours). it costs abit, i got them new shafts with steel wheels, and full rebuild and balanced, but they are now on warranty and will be good for 19 pound and 250 odd kws all day long.
    if your in south australia, take them to bill at adelaide turbo services on marion rd, he will have a look at them for you.
    also as far as oil goes each turbo should flow over 2ltr of oil on idle per minute, you can test this just buy jimming up a rig and having the oil fed into two bottles.
    Quote Originally Posted by rshuwy View Post
    How much did the rebuild set you back,mate? Mine have just started smoking and I'm tossing up whether to go single or rebuild the suckers.
    Matt.
    Gen 3 Liberty RX Wagon.
    MX83 Cressida - 1JZ Powered.
    Gen 1 Liberty Sedan - EJ20T Powered.
    Jan 2009
    sa
    i think the price is 700 per turbo, im not sure if that included new shafts or not.
    it is fairly expensive, and it isnt worth putting them back on without twin dumps, but with twin dumps, it will really fly, with minimal lag, bill actually thinks well of these turbos once you free up the exhuast y piece with twin dumps to get rid of the heat and restriction.
    if that isnt enough power for you, you can always sell the rebuilt turbos and dumps down the track as there bolt on and everybody wants them. thats what i plan to do anyway.
    south australia
    i will speak to bill tomorrow to see what he says about the turbos to see if they are my problem.
    Curiously, where did you get your dump pipes from? I have until Saturday to get this all back together again so if i can find something in that time i might as well do that as well, otherwise back to standard again (I'm not chasing horsepower, but by the same token don't want to pull any of this apart again.)
    Jan 2009
    sa
    i haven't actually put it all on, and hence i haven't had the dumps made, but i got a price from exhuast technology which was 680 drive in drive away, and that was for twin dumps from the turbos to past the firewall. and thats for a cressida.
    i have seen dumps for soarers on ebay, maybe try the soarer forums, as id say they would be abit easyer to get than ones to suit cressidas.
    Aug 2009
    theres a few sets going on ebay atm mate... just search 1jz dump pipe
    Nov 2007
    +1 for ebay dumps. Just bought some $280 Delivered.
    As for quality, will see when they arrive.
