lx90 cresta air con condenser
hey guys trying to get a new condenser for my car as previous owner pulled it out.
the jzx90 mark 2 is different does anyone know what would fit??
cheers...
Re: lx90 cresta air con condenser
what about one from a 90s surf, they ran the 2LTE as well.
What exactly is it about the jzx90 condenser that makes it not fit, same chassis so all bolts should line up. Or are the hose connections different?
Could try buy this one if your in need but make sure with the buyer it has no leaks. :
http://webcache.googleusercontent.co...&ct=clnk&gl=au
get new lines made up, should be cheaper and much easier than finding the an lx90 core
Yep, I thought so.
Just get a condenser from another X90 and use the aluminum connector ends from that condenser and get the rubber hose put onto them
i might have a lx90 cond. ill check the parts shed tomorrow
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
