Results 1 to 6 of 6
Thread: 3y in 18r out can i be done
    Nov 2009
    Default 3y in 18r out can i be done
    hey guys pulled out the 18r found a cheap turbo 3Y wanna upgrade the gearbox from 4spd to 5 so no dramas but can i get away with fitting the 3y without modifying sump maybe chance mounts to suit or is it to much drama cheers
    Victoria, Mt Macedon
    Default Re: 3y in 18r out can i be done
    Hi Adam,
    It'd help alot if you could tell us what car you're talking about. Also which 3Y you have found (I know some are rear sump, though there may also be front or mid sumps available too).
    But if you come with some more info, and preferably some more punctuation too.
    Hen
    Nov 2009
    sorry mate Bit of a rushed message. The car is a rn41 hilux and the 3y is out of a hilux also but haven't seen the sump yet. Whats involved in the swap if anyones done it? Cheers
    Jun 2007
    Engine mounts are in a different position on the chassis rails between 18R and 3Y. I would stick with the 18R if it was my ute. You can get a steel case 5 speed to bolt up to an 18R or if you want to use a G52 or W series 5 speed just use a bell housing from a hilux with a 22R engine.
    I have found it is a lot easier to get more performance out of an 18R than a 3Y because the 18R has bigger valves and ports and is a shorter stroke so they like to rev. Put a turbo on your 18R and it will be heaps better than a turbo 3Y.
    Car Alarm Guru and Grease Monkey GTtwin's Avatar
    Quote Originally Posted by Dazza View Post
    Agreed.
    A 3Y has very little useable power down low or up high, especially in carbie form.
    Even better, drop an 18R-G head on your block with a turbo and that would crack!
    Quote Originally Posted by GTtwin View Post
    Nice suggestion, but the RG head onto RC block is a WHOLE world of work, and frankly isn't worth the effort unless you have a complete RG with nothing wrong except a block specific issue (ie cracked where a welch plug goes in)
    What was wrong with the RC?? I have a good long motor with a mild cam and extractors (Celica) that you can have for bugger all more than the freight cost (check www.e-go.com.au for freight cost)
  1. 18r - 18rc front rear sump swap?
    By thdevilshands in forum Tech and Conversions
    Last Post: 15-11-2008, 08:08 PM
  2. 18r - 18rc Front Rear Sump Swap
    Last Post: 12-11-2008, 09:14 AM
  3. 18R distributors...
    By shewiththe18RG in forum Tech and Conversions
    Last Post: 06-05-2008, 11:48 AM
  4. 2TG head/ 18R block
    By quikestsilva in forum Tech and Conversions
    Last Post: 08-06-2007, 02:36 PM
