Results 1 to 4 of 4
Thread: 1ggte on gas
    Default 1ggte on gas
    hey everyone,
    im wondering what damage will occur to a 1ggte running on lpg if no upper cylinder lubricant is used? as i am looking at buying one, and i know it was run on gas and this is the reason for it dieing, however the seller is being quite cagey on the whole issue.
    also how can this lubricant be added and what sort of price would it be?
    thanx guys
    ~andrew~
    Default Re: 1ggte on gas
    The "upper cylinder lubricant" is only required on engines designed to run on leaded fuel. The 1G was built long after Japan switched to unleaded, so it will be fine on LPG.
    ok thankyou, thats sort of what i thought from the research i'd been doing.
    in that case do you know what happened to the 1ggte running on gas owned by the fellow who goes by "1GGTE KE70" as the fellows on rollaclub have said he said it died because of the gas and no upper cylinder lube, and he wont tell me whats happened with it.
    god i hate hearsay
    thanx in advance for any answers i get
    ~andrew~
    You've got your answer.
    Take your fight off forums.
  1. 1ggte misfire when coming off gas
    By 86TT in forum Tech and Conversions
    Last Post: 23-02-2006, 07:02 AM
