my MS did this when i first got it to idle - turned out my earths were up the shit.
Some of the MS guys run separate earth return for each sensor that doesn't earth thru the engine - also separate the earth for the igniter from the ECU. The fact you've got noise when the coil is in play suggests its not filtering ringing from the coil.
My coil driver (3 pin chip instead of toyo igniter) is inside the cabin but the earth it's providing goes right back out to the mount for the coil.
You should snaffle Wilbo's CRO to check that you do have the polarity of the dizzi VR sensor around the right way.
Off the wall: did you check the air gap between the VR sensor and the toothed wheel in the dizzi? If it's too wide you will get poor signal (especially at cranking).
