Results 1 to 10 of 10
Thread: How to fit TA22 discs onto RT40
    Basher Grease Monkey
    Feb 2007
    Default How to fit TA22 discs onto RT40
    you will need:
    front discs calipers and hubs from a PRE mid 74 ta22 the ones with the "small" bearings,
    11mm drill bit,
    angle grinder.
    Step 1
    strip front hubs down to bare spindles on rt40 then fit ta22 backing plates with 2 diagonally opposite bolts.
    Step 2
    using spindle as a drilling guide,drill the 2 new holes,you will also need to remove a small amount of metal from the lower part of the backing plate as circled in pictures below.
    bolt on backing plates remembering to fit split pins to the required bolts,install hubs and calipers.
    Brake hoses are from an rt81.
    you can upgrade the master cylinder using a ka laser master cylinder to a dual circuit type,no brake booster needed but can use a remote booster if desired.
    Scott
    coronacoronacoronacorona
    Toymods Club Member Grease Monkey brum's Avatar
    Default Re: How to fit TA22 discs onto RT40
    Got all this gear but never got around to working out how to make it fit.
    Thanks for the write up, will help in the future.
    '69 KE10 Corolla
    '69 RT40 Corona
    Aug 2011
    Brisbane Qld
    Having a problem bolting the calipers on please help ????
    Feb 2007
    what is the issue?
    Aug 2011
    Brisbane Qld
    Hi sbfoot
    1st would like to say this was an awsome guide helped alot
    but my problem is i can get my calipers on i can put the bottem bolt on but the top one is hitting on something and is missing by about 3-4 mm
    Alex
    Feb 2007
    can you post a pick of the redrilled backing plate please.I can't think why they don't fit.
    Scott
    Low rep Grease Monkey
    Apr 2010
    bkk
    good luck bud
    Aug 2011
    Brisbane Qld
    Hello sbfoot i figured out the problem LOL but i am having another one the back brakes now lock on with the ka laser master cylinder did you have this problem cheers Alex
    Feb 2007
    Hi Alex,
    I use standard size rt40 wheel cylinders and don't have an issue,make sure your shoes are adjusted correctly (mine are more likely to lock up when not correctly adjusted.)and your lines at your master cylinder are fitted to the correct circuit I think the master cylinder has an f for front and r for rear,next time I have the back wheel off I'll double check the wheel cylinder size.What year model rt40 do you have?does it have load sensing brake proportioning valve at the rear that allows more rear brake bias when vehicle is loaded?
    Scott
    Forum Member 1st year Apprentice 20valve69corona's Avatar
    Fixed the problem
    By The Witzl in forum FAQ
  2. [Guide] "How to fit RT142 rear disc's to most 4 studs"
    By GA61XX in forum Engine & Driveline Conversions
    Last Post: 02-02-2015, 06:39 PM
  3. Wheels and offset for TA22 with "F" series diff
    By "Z" UTE in forum Tech and Conversions
    Last Post: 28-09-2007, 12:58 AM
