Hi timcorona,
Lag followed by light switch style power band I'm guessing... Great for spectators!
I would suggest that the question of hard to fit or not depends on your skill level and or bank balance.
The T04 I'm guessing is a T3 exhaust flange?
The T28 or GT2860 are both T2 exhaust flange, so an adapter, manifold modifications, or replacement manifold would be in order.
Now I'm not the turbo guru, however I would be bold enough to suggest the smallest T3 flange garrett turbo GT3071R with a .63 exhaust housing for good spool performance might be worth considering. This could be a bolt up to the manifold solution and possibly suit existing water and oil lines.
As for dump pipe you will most likely need something fabricated or at minimum a new flange welded to existing dump, and intake side 'might' get away with a new silicone adapter hose if very lucky!
Thats my 2c worth anyhows.
By the way any vids or pics of car on drift circuit???
Jason
				 a bit of  turbo help
 a bit of  turbo help
