Results 1 to 13 of 13
Thread: r154 box differences
    your mums an Carport Converter pato's Avatar
    Default r154 box differences
    so u can get the r154 box on
    ma70
    jza70
    jzz30
    jzx90
    jzx100
    and iam sure alot more.
    basic question is. apart from the remote shifter is there any other differences between the boxes, particularly when the 1jz is concerned.
    i have a jza70 box, with the bellhousing to suit non vvti 1jz.
    i want to put it in a jzx100 chaser, but iam not sure wether.
    starter motor is in the same place ?
    1jz and 1jz vvti bell housings are identical ?
    the gearbox mounts will bolt straight up to both ?
    any help will be appreciated
    Blake
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    Default Re: r154 box differences
    I can say for certain the shifter won’t come up through the factory hole
    Quote Originally Posted by pato View Post
    starter motor is in the same place ? YES
    1jz and 1jz vvti bell housings are identical ? YES
    the gearbox mounts will bolt straight up to both ? Perhaps.
    Blake
    First two are easy 'yes' answers.
    Last Q is a maybe... I've seen early R154's that didn't have the required provision to take the later model gearbox mount.
    Also as said the JZA70 shifter will be in the wrong spot for JZX100.
    Wilbo's JZA80
    Wilbo's JZZ12
    yea i knew about the remote shifter
    driftmotion, as a last resort can make something up that will be any length i need
    its just the other questions i need addressing mainly.
    anyone know of anyway i can find out for sure about the gearbox mount ????
    photos, etc
    I'm pretty sure this is a modified JZX100 mount.
    See how 2 holes are far away from the other 2?
    Pretty sure this is JZX100
    This is early JZZ30
    This is MA70 and JZA70 (see how its missing the rear 'upper' holes for the tranny mount?)
    Another MA70
    ahhhh... thanks cruzida..
    thats the best help ive had by far
    so it seems from that... that my box wont just work with the standard gearbox mounts for the jzx100....
    are there many 100 boxes floating around ? it may be easier just to sell mine and grab one of them yea ?
    would i be able to get a 100 mount modified to fit my box u recon ?
    blake
    Probably easier to source a JZX100 box, or at the least rear housing and shifter/etc.
    These guys might swap rear housings/etc
    http://www.toymods.org.au/forums/showthread.php?t=58558
    Mar 2009
    Auckland
    i have a picture of the r154 mounts that are used if your interested?
    yea man definatly interested
  1. r154 shifting experiences
    Last Post: 24-11-2009, 09:47 PM
  2. R154? Good or no good?
    By TTV8RA23 in forum Tech and Conversions
    Last Post: 12-02-2008, 09:18 AM
  3. R154 Rebuild Questions
    By delazy in forum Tech and Conversions
    Last Post: 22-08-2007, 06:14 PM
  4. Replies: 0
    Last Post: 30-08-2005, 08:43 AM
