Results 1 to 15 of 20
Thread: What Gearbox is this???
    Default What Gearbox is this???
    Hi i was given this gearbox by a guy down the road from me he said it was a toyota gearbox but i cannot find any number on it to identify it. Ive taken some photos so maybe soemone knows by just looking at it? both shafts have 21 teeth on them. Thanks
    Default Re: What Gearbox is this???
    do you know how many gears at least?
    Toyota boxes are known for being crap to identify
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Nope have no idea lol im just assuming it is 5
    k50? t50? something like that..
    i think k50s dont have a removeable bell
    hI,
    last t50 i looked at was about half that width. They are tiny.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    definately not a t50, much smaller and they slit in half lengthways. this looks more heavy duty possibly out of an early hilux? maybe even a toyota stout
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Kinda looks like a G5x, but I thought they had a 4th rib across the top like the W5x does.
    The R15x doesn't have the 4th rib, but it doesn't look big enough.
    Go get a W5x bellhousing and see if it fits.
    Are all the W series bell housings the same? Other problem is i dont have a shifter i i really need to know what it is so i can get a shifter for it.
    i'd be going for a g5x as a guess too. The shifter part of it looks different to any w5x i can find
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Oh, and also no, w50 takes a different bellhousing to w55/57/58.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    what do the g5x boxes come out of and are they any good?
    Identical internally to W5x boxes, however gear ratio's are more set up for commercial use.
    Found predominently in Hilux's and Hiace's (and things of that nature)
    Mar 2009
    NZ
    It's out of a 2WD Hilux. I'd say its a W56 with a different tail shaft to the 4wd W56, they are exactly the same except for the tail housing which can be swapped over.
    Nice and strong. Slightly funny ratios though.
    Junior Member 1st year Apprentice 1jza21's Avatar
    Calif
    Looks like it might be a 4speed because of the short area behind the center plate. Maybe a W46 or so. They have a really odd gear ratio. Here in the states they ran a 3.08 rear gear for these trannys. Great for drag racing with 4.10-4.30 gears though. Good luck with it.
    1972 Celica 1JZGTE TH350 Tubbed etc.
    http://www.toymods.net/forums/showthread.php?t=50114
    are the gears interchangable between the W series boxes?
    Just looked up the ratio difference between a W56 and a T50 as i have a T-18/TE72
    W56
    1st - 3.954.1
    2nd - 2.141.1
    3rd - 1.384.1
    4th - 1.00.1
    5th - 0.85.1
    T50
    1st - 3.587.1
    2nd - 2.022.1
    3rd - 1.384.1
    4th - 1.00.1
    5th - 0.861.1
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Verifying a w58 gearbox
  3. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
