Results 16 to 23 of 23
Thread: Turbo A 7m wont run with map sensor vac line connected
    Default Re: Turbo A 7m wont run with map sensor vac line connected
    I know F all about wiring and such - but just in case its something simple - could the vaccuum lines be around the wrong way Matty?
    *shrugs*
    Thats as helpful as I can be
    Will be keeping an eye on this thread though
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    could always be a bad ecu? when i threw 12v across the 5v side in my ecu and cooked the caps i found it would run without the map sensor but not with it connected, but put on a good ecu and it worked fine
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    May 2008
    My call is fuel pump also. Does this particular engine have a fuel pump voltage switching circuit with fuel pump resistor?
    If so, is one of the determining factors of fuel pump voltage the map sensor output?
    Could it therefore be having trouble running at low voltage, only working at high?
    -Tristan
    You raise a good point Tristan.
    While I can guarantee they aren't using the fuel pump resistor (thus voltage isn't an issue), do you have the COR hooked up to the correct output?
    ie, is it accidently hooked up to the fuel pump resistor relay output?
    May 2008
    In ammendment... engines require very little to run. Spark, fuel, air.
    Monitor all aspects of each of these (fuel pump, injector operation if possible, ignition etc).. and find the one or ones that are stopping when the motor stalls.. knowing this will narrow down the possibilities significantly
    this problem has been rectified by the way...
    7M has been up and running for a few weeks now w00t!
    Err...what was it?
    Quote Originally Posted by JustCallMeOrlando View Post
    Err...what was it?
    a valid question...
    the answer I got was "no idea"...
    but what I suspect was it was something simple that matty stuffed up and is too embarassed to admit
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 01:02 AM
  2. Turbo maps - a quick guide
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 21-08-2006, 02:10 PM
  3. Boost Leak Tester
    Last Post: 01-06-2006, 12:25 PM
