Results 1 to 9 of 9
Thread: twins or single dilema
    Jan 2009
    sa
    Default twins or single dilema
    my turbos on the 1j are really starting to smoke now, its time to address them...
    i do have a pair of Chinese ct12a copy's that i was considering putting on, but i think they are on there way out aswell and may need a rebuild. and there unreliable as and crap i was wondering if you,
    can you go single for under 2k? has anybody done this for around this budget? if so what setup did you do? and ruff cost's for each?
    i dont want big power or anything just something that will do the job.
    Huw
    May 2006
    Default Re: twins or single dilema
    Probably best to look at this thread a bit down the page champ
    http://www.toymods.org.au/forums/showthread.php?t=58256
    You could always go a cheap Chinese manifold, with an eBay turbo etc, but then you have to factor in a new dump pipe, as well as inter cooler piping and an induction pipe. It is also best to probably chuck something like a SAFC on to make sure all the air fuel ratios are sitting right and get the most out of the turbo without going stand alone management, etc
    Aug 2009
    theres a few sets of 1jz turbos floating around for very cheap atm mate... and im sure if you posting in the wanted section youll score some very cheap in good condition...
    for under 2k youd be buying chinese crap, yeh the manifolds do the job, but i wouldnt risk a chinese turbo
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Quote Originally Posted by rshuwy View Post
    Huw
    are they steel wheelies? i've got china steel wheelie CT12A's on my JZX90 and they effing pull. if they are, put them on and enjoy the louder whine and later spool (bit laggier than the ceramics.. but hell do they pull when boost kicks in.)
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    Jan 2009
    sa
    yer there Chinese ct12a's which are steel wheeled, i think ill drop them into Adelaide turbo services next week and see what they think.
    im abit iffy about buying second hand twins as the quality of them is suspect.
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    For @ $2K you can get Hypergear to Hi flow your shagged standard ones, I would rather spend money doing that than rebuilding chinese ones, thats just my opinion though.
    Jan 2009
    sa
    yer that would be ideal, although i wasnt looking to spend that much on rebuilding them, i was planing on doing it myself, depends on what Adelaide turbo services think of them.
    i think i was quoted 1300 a turbo to highflow + steel wheel.
    Jan 2007
    queensland
    have you just looked into doing a 6 boost or ECE single manifold with a T3 foot, and running something like a KKR or proBoost gt30/35 equiv... you can even get low km xr6t garret's pretty cheap on the ford forums... there a bit laggy... but not rediculous... 1JZ's seem to moove alot of air
    do you have a local fabricator (like an exhaust shop, or place that makes rollcages) capable of Tig'n a few pipes (new cooler, air intake, dump pipe) you should be able to do it for a similar cost (prolly a bit more depending on what the guy charges..)
    Jan 2009
    sa
    i was looking at 6 boost manifolds from horsepower in a box, i think it was 1300 for the mani alone so that kind of counted it out..
  1. 1JZ big (ish) single on stock ecu?
    Last Post: 16-11-2010, 08:30 AM
  2. Soarer spat it's twins, is now single. Achtung Keiner 56k!
    By jzk25 in forum Engine & Driveline Conversions
    Last Post: 14-01-2008, 07:40 PM
  3. 1JZ bigger twins or a big single???
    By GZP51 in forum Tech and Conversions
    Last Post: 31-08-2006, 03:07 AM
