Some that I know the answer to off the top of my head
You can buy the parts from Toyota. Get the part numbers from www.toyodiy.com ...
It adds up to cost a fair wack, around $400+ if I recall when I priced all the parts required!
Another option is to lengthen your existing shifter (Cut and weld the upper housing).
Slave will. Master is a maybe, I'm not 100% sure but I suspect you might need the jza80 style clutch master that slopes away for clearance...
Yep
Yep bolt patters are different I believe.
