1UZFE VVTi
Variable Cams
Inlet
Actuation
Factory Sensors
Cam Sync -
Fixed single tooth on left bank inlet camshaft. The sync pulse is fixed at 90 degrees BTDC and does not move with respect to crank.
Crank Trigger -
36 minus 2
Cam Position Sensors -
Left and right intake cams have a 3 lobe trigger, with odd 'Y' oriented lobe positions. One lobe positioned at 90deg and two at 135 (insert pic as that's not clear). Passenger side bank contains cylinder #1 and trails the drivers side by 90 degrees.
Questions to Solve
-Why 3 oddly arranged lobes are required to accurately position the cam with respect to a TDC trigger. as opposed to say 3 evenly spaced lobes, or even just one single lobe. why three (when theres already a cam sync on the front of the camshaft) and why oddly spaced?
Crank trigger and Cam Sync are all that's required to run the engine and provide full cycle timing for fully sequential injection and ignition events.
Assuming it's the same as the 2JZ so added above. If i'm incorrect in that assumption let me know
