Results 1 to 15 of 18
Thread: Stud patterns
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default Stud patterns
    hey guys been doing a few searches on here and the old forums and other sites and i could not find toyota stud patterns.
    what i wanted to do was create a thread that created a list of all toyota stud patterns and the best offset to be used.
    like early celicas and sprintahs use the 114.3x4 stud pattern but i am unsure of the best offset that is to be used.
    this could be really good reference to people who are buying wheels from stores,ebay or even group buys that allow you to order your wheels with what ever offset your require.
    this could be very useful to myself who has a 23 and looking for a set of wheels.
    REgards
    ibz
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Default Re: Stud patterns
    early KE10 and KE20 have 4x110mm, later KE20 (some?) have 4x114.3.. most later than that have 4x114.3 until FWD.
    instead of offset, it might be worthwhile to compile a list of rim diameter and rim backspace at which the rim hits the strut.
    tyre bulge can vary from none to a couple of cm, and rim offset can be calculated from width and backspace...
    width is also important for guard clearance...
    Sounds like someone needs to put together the...
    Toyota Stud Pattern, Offset and Backspace Database!!!
    FTW
    i was about to say offset is better as you can calculate backspace from it, but if you specify rim width and backspace, then you don't need to explain the offset convention.
    i'll do some measuring, and maybeye post up a little guide how to measure backspace for the noobs.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    there's tons around dude, people are just too lazy to google it and work out how to measure it :\
    ra23/28 afaik is 4 x 114.3 on a 5" wide rim std with +32 offset.
    some1 told me this once or I found a spec sheet.
    im running 13x7 at -10 offset with no issues... i have flares but rims are flush with guards.
    Black Betty >HERE!<
    (\__/)
    New Zealand
    Backspace is hard to measure unless rim is stripped, along with an accurate width. Offset can be measured much easier with tyre still on rim.
    Pull the wheel off and lay it face up on flat ground.
    Measure from ground to the hub mounting face (call this A), then flip over and do the same (call this B, make sure this is still to the same mounting face). Add A and B together and divide in half (call this C). The difference between C and A is your offset, If A is more than C the offset is positive if less its negative. You need to be pretty accurate with your measuring though.
    Callum
    Wezelton Grease Monkey
    I've run 15x7 +25 on the front of my RA60, they cleard, but where close. im now running 15.8.5 -15ish (maybe lower) but have flared guards. Rears have run 16x9 +25 before, scrubbed very slighty on very hard cornering with a full car pretty much on bump stops, but werent that close to the guards.
    Wes.
    Bitch, come over here and have sex with Charlie Murphy..
    Im Rick James bitch!
    Quote Originally Posted by WDE_BDY
    that is very true.. however, given that different rims have different thickness at the bead depending on design, i guess i meant "distance between hub mounting face and strut for different rim diameters" as opposed to technical backspace...
    so i suppose offset, combined with a nominal bead/tyre bulge width is as close as you can get to a nominal measurement?
    User Conversion King
    NWA
    on the offset topic - XT130 struts can run a greater offset rim than RA40 struts.
    they can run as far as a 15" x 7" x 40 offset....with about 5mm tyre bulge
    hello
    FTW
    I have a book that has 99% of cars stock wheels in it...
    New Zealand
    I would probably go with offset and tyre size as generally speaking the tyre should be wider than the rim, except for massive dorifto style stretching.
    For example, my KE70 runs 15x6.5" rims with P20 offset with 205/50 15's. I can go to 7 or even 8 inch rims with same offset and the tyres will still clear. However if I get a 5 inch rim with P35 offset the rim will clear but my 205/50 tyre won't.
    Callum
    less yap more tap tap ... or scan scan
    Black Betty >HERE!<
    (\__/)
    Gents...
    I think this is a reasonably exhaustive guide
    http://www.stradlater.com/upload/upl...tguide0803.xls
    Facebook | LinkedIn
    hmm, my tyre sidewalls are exactly in line with the edge of the rim... 215/45/17 RE-01R on 17x7.5, aint no dorifto action goin on here
    with tyre size, the bulge changes with rand and model,... but i spose this is all just a rough guide anyway
  1. Early corona 5 stud conversion and big brake's
    By SRacin in forum Tech and Conversions
    Last Post: 22-09-2010, 09:32 PM
  2. MA61 - 5 stud bearings used?
    By ZZT231 in forum Tech and Conversions
    Last Post: 31-03-2006, 12:22 PM
  3. I need a stud!
    By Matty P in forum Tech and Conversions
    Last Post: 20-01-2006, 07:33 AM
  4. echo stud pattern
    By wokstr_ae86 in forum Tech and Conversions
    Last Post: 14-12-2005, 01:46 PM
