The MA70 is a direct bolt up to the booster but you will have to re route the brake lines to the m/cyl as they dont quite line up. You will have to check them against the earlier ones as far as calipers go as I am unsure.
hey all, i need some clarification on some info i found around here.
are the MA70 brake master cyliners a direct bolt up for RA23's? or are there modifications necessary??
also, regarding the pug/corona/lux brake conversion for the RA23's, has anyone used current model SR5 hilux calipers instead of the LN106 ones? as i have a pair off a 2007 SR5 diesel doing nothing and if these will work then all the better.
thanx in advance
-James
my RA23 http://www.toymods.org.au/forums/showthread.php?t=57060&page=2"]
It's 106 miles to Chicago, we got a full tanks of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
- Hit it.
Cheers Dave
1977 RA28
1972 TA22
1984 Supra
awesome thats easy enough. cheers mate
- Hit it.
what about the GA70 would that be the same as the MA70 ?
and the RA23 & RA28 are the same bolt patten.
Ga/ma70 have the same master cylinder.
im using a ga70 one in my ra23(straight bolt on with line mods as stated) with hilux calipers and stock drums, work a treat.
GA23(never finished-now with cracked block) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
- Hit it.
