You need max and min volumes to determine compression ratio, and since you have the CR and stroke of each motor, then use that as a starting point.
Though, I would suspect it would be 8.75 - assuming that all 3S-GTEs have the same stroke so the difference in compression ratio comes from the associated head/HG combo (sicne you used the ST215 HG and head on a ST205 bottom end)
