Originally Posted by
JP
Have you had your current radiator cleaned properly? not just flushed, tank removed and rod put down the cores to clear the crud out?
I've found the stock one worked quite well at sprints etc when there's also an engine oil cooler installed. Temps didn't get anywhere near 120deg in the 7 laps at full noise. This is with the stock 20V radiator, cleaned properly (was 40% blocked straight from japan) and using toyota long life coolant with a new genuine thermostat and the system burped properly.
