no-one here has done this particular engine yet, but it would be similar to a 3SGE conversion (similar dizzi configuration of 24 tooth wheel plus 2 x single teeth wheels) and the few 7mgte conversions that have been discussed on www.msefi.com.
Currently listed successes are here and i'm just about to join them.
There's someone in Sydney who has done 3SGE conversion using all the stock sensors (a search of here or of the old forums should dredge up a name).
you biggest issue is going to be a lack of fuel and spark maps not hardware configuration... is a lot of work to get various bits setup but then a new world of tuning and tweaking will follow
I'd suggest:
use the 24-tooth wheel and modify it to a 12-1 wheel (remove 2 teeth at the right spot)
run 3 x waste-spark coil packs (so you get more room for that big-single turbo)
run MsnS-Extra
You'd need a single VR interface and 3 coil drivers - all very simple to setup if using circuits from here.
cheers,
Charles.
