Results 1 to 10 of 10
Thread: interior lights
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default interior lights
    has anyone had a problem with the lights on the temp/fuel and ingnition and oil lights on a TA/RA23 dash.
    they use to light up all the time one they didnt i tapped them
    and they worked again. but i tapped them tonight and they refused to go on.
    i am assuming that there is a loose wire but i want to know
    if it could be anything else before i rip out the dash.
    cyaz
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Default Re: interior lights
    fuse? usually for things like dash lights it's a poor earth between the dash and ground... it's pretty common for many old cars..
    stu i dont think it could be a fuse because the lights on the speedo/tacho and clock are still working.
    bulbs blown? they do that eventually
    yeah maybe its the bulbs blown and when you tap them the little element is joining for a little while. Now it probably wont reach. Either that or yes bad earth. The multimeter is your friend.
    prob what im experiencing atm.
    30yrs + wire = frayed and brittle.
    most likely a break in the wire ... tapping closes the gap ... bumps and wire heat opens the gap.
    my dash light drops out and tacho seldom works unless i reach under and push the loom upwards.
    just havet goten to it yet.
    most liekly the earth as mentioned that its happening too.
    Black Betty >HERE!<
    (\__/)
    Junior Member Domestic Engineer magicmitch's Avatar
    Nsw
    i got a prob with my dash light also...as 1st gen celica owners will know that there is a dimmer switch on the right hand side of the steering wheel..well at its brightest its still very faint...its not a fuse..could it be bulbs?
    WANTED- MS55 front and back bench seats, good condition
    1970 MS55 Crown
    prob bulbs... as mine are slightly faint and my dimmer lives in a bucket in the garage.
    also aged wiring (as we have) will stop proper current flows etc effectively 'dimming' lights.
    Black Betty >HERE!<
    (\__/)
    In the words of the immortal Cool1: Bad earth?
    you might be surprised how dim the bulbs get before actually dying... back in ye olde days, the filaments must have been a bit thicker, so they last a long time, but get very dim...
    swap them to new ones anyway.. only a couple of $ for em
    and then do wiring/earths...
