Its which port the usb is plugged into.
Device management is one way to find out which port.
com port is what? lol
i just got one going with mine
go to my computer properties, then hardware, then device manager. look for what com port it's using. go into halwin program setup and choose that port.
ryley
ecko are you still using the standard 7M coils? can you tell me the dwell time and charge time under ignition setup, if you can connect to the ecu?
thanks mate
ryley
Sorry for being a bit off topic, but this seems strange to me. I would assume that ECUs would express the fuel map as either ms opening time or % injector duty cycle for each rpm/throttle/MAP point. So provided you know the injector size and fuel pressure you should be able to calculate the fuel map.
As this is not the case, how do they record it? And, if anyone knows, how does it vary between different brands?
Microtech LT8 Auto. CT26 highflow:
My setup is nearly identical and running a Microtech, I've got the values in a spreadsheet on my work laptop.
Flick me an email there and ill reply when I get back to the office, [email protected]
You don't have a 5ME sump by chance do you?
Sent from my SM-G950F using Tapatalk
Thanks Paul
