Results 1 to 5 of 5
Thread: 4AGE clearances
    Default 4AGE clearances
    Gday guys im starting to build up a mildly moddifyed 4AGE
    but want to know what valve clearances people use?
    according to the 4AGE adv. specs thread
    Inlet: 0.15-0.25mm
    Exhaust: 0.20-0.30mm
    should i be aiming for smack in the middle or slightly above the middle range (as it decrease over time as the shims wear in?)
    whats the adverage increment on commonly avaliable shims?
    [BNS70Y] + [BNS20Y] Backyard Mechanic
    Default Re: 4AGE clearances
    Are you using standard Toyota shims???
    If so, I would say slightly above middle range...
    Ben...
    south australia
    Have you considered this:
    http://www.toymods.net/forums/showthread.php?t=4385
    Could be a good solution to your problem.
    thats a good idea, i might not be going down the 4AGE route now, will see in teh next few days
    S.A
    I aim for the middle or a little higher
    The clearences get smaller because the valve after opening and closing so many times actually smacks itself up into the head further hence closing the valve clearences up !
    P.s merc blue : did u get your p.m?
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 10:42 PM
  4. 4age engine mounts
    By duff_boy in forum Tech and Conversions
    Last Post: 03-03-2006, 12:35 AM
  5. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
