Results 1 to 12 of 12
Thread: Weird 4agze ABV from imported halfcut
    Sep 2009
    Default Weird 4agze ABV from imported halfcut
    Well pictures explain it all, very curious to know what it does exactly... I'm tempted to pull it apart and look inside, at a guess i think its mechanical adjustment for the abv, but im not certain, the top has no traces to the original diaphram and im just all out confused really. Came on my ae101 levin GTZ halfcut that came straight from japan with a cusco crank pulley and and cusco PS "powerball" headers. Is this also another cusco part offered to these engines?
    any info would be greatly appreciated.
    xoxox
    Sep 2008
    Default Re: Weird 4agze ABV from imported halfcut
    Wow that is weird. Looks similar to my abv but that screw type adjuster in the to is wickity whack
    The GOD HAND AW11 - sold
    Sep 2009
    just been told its a cusco adjustable ABV, pretty hard to come by, me thinks ill hold onto it haha
    Junior Member 1st year Apprentice Grippy's Avatar
    It looks like the Cusco ABV for the 4agze, good score.
    perth
    yeh its an adjustable abv, ive seen a few of them on import gze's.
    Sep 2008
    Weird. Put it on and report back
    Oct 2007
    i had one on my gze they do a good job.
    Feb 2007
    What's a ABV?
    Sep 2009
    basicaly a pressure regulator
    A warning to all others! Backyard Mechanic
    Dec 2009
    CA
    Yeah, it is a Cusco abv. They apparently replaced the top portion of an oem abv with their own, which has an adjustor bolt on it. They allow you to run larger crank pulleys, and/or smaller sc pullies without having to resort to the abv mod to make use of the higher boost.
    And yes, they are pretty rare. try googling them and you still get next to no hits on them. I finally found one on Yahoo Japan, and had to pay dearly for it, considering the shipping and handling costs.
    I'm really looking forward to using it. From what I have seen posted, although not confirmed yet, they supposedly allow for up to about 15 psi of boost, which is probably about max that you would ever see on a 4agze that is still set up to use one of these.
    Good score!
    So long and thanks for all the fish!
    Quote Originally Posted by 88MKIII 1G-GTE View Post
    What's a ABV?
    Air Bleed Valve, allows the air pressure created by the Supercharger to bleed back into the intake when the car is on half or closed throttle. Kinda like a Blow off Valve.
    Jul 2007
    proper name is AIR BYPASS VALVE, and it comprises two functions
    1) boost control
    2) decreases pumping losses when the supercharger is disengaged as it allows the air to bypass the supercharger, thus improving cruise economy by some 15% according to some articles i've read
  1. 4agze build questions
    By ae86boy in forum Tech and Conversions
    Last Post: 06-11-2011, 03:59 AM
  2. 4AGZE Compression Advise needed
    By _FNQ_rolla_ in forum Tech and Conversions
    Last Post: 26-10-2008, 09:25 PM
