Results 1 to 5 of 5
Thread: Aristo jzs147 Fuel pump control ecu - Where is it???
    Oct 2009
    Default Aristo jzs147 Fuel pump control ecu - Where is it???
    Trying to find the Fuel pump control ECU in a JZS 147 aristo 2JZgte, where is it hiding? Does it have any other markings on it? What colour is it?
    Default Re: Aristo jzs147 Fuel pump control ecu - Where is it???
    ToyoDIY.com
    Should have the part number 89570‑30160 on it I believe.
    Located at the rear passenger wheel well of the car (89570A in the below image).
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2009
    That would explain why i don't have one, i got a half cut. I couldn't get the engine to rev past 4000rpm when in neutral or park, thought i may have been overfueling it. Now i have found there is a limiter on them in park and neutral that wont let you free rev it. Thanks Wilbo, i have been using a lot of your diagrams .
    all it does is drop the fuel pump voltage - without one it'll just run a constant 12v, just like every other car out there
    Apr 2010
    queensland
    ^^^ as he said above. i have one from a supra if you need one? pm me if you do?
  1. Toyota Fuel Pump ECU - Supru/Soarer/Aristo - The same???
    By PT1 in forum Tech and Conversions
    Last Post: 23-03-2007, 10:08 AM
  2. Suspension for JZS147 Aristo
    Last Post: 16-08-2006, 07:52 AM
