probably pinging (detonation)
did it start after filling up with fuel - maybe a bad batch
had it tuned recently?
neil
Hey guys,
My GFs Barina is making annoying rattling noises from the engine bay while accelerating or going up hills. it sounds like somethings loose like bolts or something. Anyone got any ideas what it could be??
Thanks guys
90' GT-Four ST185 RC motor ST205 gearbox!
New installs Ct20B and Rear Strut Brace!!
Next to come;
3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
neil
2009 aurion
Purple 2000 Hilux - 1UZ![]()
I would second that, next time the car is near empty, try filling it with a batch of Premium fuel... Late Barinas (both Euro and Korean) seem pretty bad for Pinging.. As did Camiras before them.
The good people at Wiki have a bit on Pinging.
http://en.wikipedia.org/wiki/Engine_knocking
My sister in laws Barina (the opel corsa ones) sounded awful and even a bit like a diesel, down on power n horrible with passengers simply because the timing belt was overdue to be changed. Might be worth checking that out.
tell her to stop putting safeway fuel in it
Never late in an x8
check bolts on the exhaust heat shield.
It is pinging / knocking. Almost every barina will do it under heavy load, especially an SB / XC, especially an automatic.
Fill tank with BP 98 octane, never look back.
It will stop the pinging, help GREATLY with the heavy carbon build-up problems the Z/X 14XE motors are prone to (if it is the last of the euro-made barina model, the XC), plus normal benefits when switching to 98 octane.
Don't change into higher gears when going up hills etc on hot daysMy AE92 corolla does it too on hot days, I have to hold it through the gears longer on those occasions.
244rwkw / 328hp @ 18psi
Never late in an x8
She would never buy that shit, got her into that habit. BP is normally pretty good.. put the plug back to 91 and its pretty good now, havent heard the sound.
she wont get 98 though, costs too much. DW i always get 98. have to with my ecu anyway
Thanks to all that posted
Next to come;
The "plug" is located between the strut and firewall. has 91 on one side 95 on the other. according to the owners manual it will "tune" to the fuel if you change the plug around.
Next to come;
why would you change the octane rating plug over to 95 if you're not running it on 95?!?!?!?!?!?!!? This advances the ignition timing in an attempt to make more power in markets that have higher quality fuel than us.
Don't touch it unless you plan to put the right fuel in it
It just advances the ignition timing by a few degrees.
