Results 1 to 5 of 5
Thread: 3s-gte - Haltech E6X
    Default 3s-gte - Haltech E6X
    Hey guys.
    Just wondering if someone could please post their complete set of settings for an e6x in a running 3s-gte.
    I'm trying to iron out some problems and want a definite list of the correct settings!
    Thanks.
    AE93 GTi - 3s-gte
    Junior Member Backyard Mechanic jzk25's Avatar
    Default Re: 3s-gte - Haltech E6X
    What problems are you having?
    You could call haltech you know.
    Got a no spark issue, just want to make sure that my settings aren't killing my igniters!
    And just want to make sure that I have the same settings as someone with a running 3s-gte.
    AE93 GTi - 3s-gte
    Ok so I have found the issue.
    I was having a no spark issue. One minute it was working, then all of a sudden car wouldn't start. Would get a single spark when I went to start the car and single spark when the key went from 'start' position to the 'on' position.
    Pulling my hair out, I checked the wiring like 10 times, sent the dizzy off to be checked, changed leads, changed igniter, changed coil. Checked pretty much everything under the sun to do with the ignition system.
    Finally I realised the ECU (Haltech e6x) was losing power when cranking as I had the laptop hooked up to it and it would disconnect from HalwinX every time I cranked! Further investigation found that the 12v ignition feed that goes to the e6x was losing 12v when cranking!
    Traced it back and found the ignition switch to be faulty
    Just thought I'd share for anyone else with the same issue.
    BTW my car is an AE93 Corolla with a 3s-gte transplant.
    AE93 GTi - 3s-gte
    Sounds like you had it connected to accessories instead of ignition
  1. Haltech E8 - Problems with 2JZ VVt trigger
    By jzk25 in forum Tech and Conversions
    Last Post: 22-06-2008, 05:12 PM
  2. 2s 3s conrods
    By bmxer54 in forum Tech and Conversions
    Last Post: 30-03-2007, 08:27 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
