Results 1 to 15 of 16
Thread: Injector Seals? Where to get?
    Default Injector Seals? Where to get?
    Where do I get Injector seals from? For 7m-gte injectors.
    Not too worried about fancy or anything, but you know.
    Facebook | LinkedIn
    perth
    Default Re: Injector Seals? Where to get?
    any injection shop or parts store (repco, veals, covs).
    anyone that cleans/service's injectors will have them.
    Bearing shops generally have a large variety of o-rings.
    Chiba
    If they're standard o rings, it's probably a good time to upgrade to viton for a few extra dollars.
    Viton?
    I went to bearing places and Ripco, and none of them have them.
    I guess it's off to an injector guy.
    Facebook | LinkedIn
    Chiba
    Viton is a high temp version of rubber. It lasts a lot longer in an engine due to it's resilience to heat and solvents.
    Where do I get said things?
    Facebook | LinkedIn
    Chiba
    Any o-ring or bearing distributor.
    Hrm, think i would be getting proper injector o-rings from a injector servicing shop.
    While the Viton seals may be ok, i wouldnt be taking that gamble.
    Having an o-ring split could be disastrous.
    oring split would mean big fire yeah?
    Facebook | LinkedIn
    Chiba
    Normal o-ring seals are often standard rubber. Viton is a high temperature version with less susceptibility to cracking. We were supplied with viton with the 330cc Bosch injectors we put in the Jeep.
    For this application, viton is in all ways superior to rubber. It doesn't harden or crack with age like rubber, nor does it ozone crack. Abrasion resistance is superior, as well as compression and tear resistance, and it's resistance to hydrocarbons is superior too.
    http://www.dupontelastomers.com/Products/Viton/apps.asp
    http://www.dupontelastomers.com/Products/Viton/auto.asp
    http://www.dupontelastomers.com/Prod.../fuelSeals.asp
    But hey, if you're not sure, stick with rubber.....
    Just tell me where to get it. :-)
    Bloody CBC said they had nothing like it, so I don't know where else to go.
    Facebook | LinkedIn
    Chiba
    Driftmotion has them in stock, the only thing will be shipping since they are US based. I cant seem to find anything in regards to international shipping but I suspect with such small parts that there wont be a problem.
    http://store.driftmotion.com/static/...ro-ringkit.php
    Feb 2010
    AFI Australia (Australian Fuel Injection)
    http://www.afi-australia.com.au/
    they are located in Granville NSW what ever u want, generally they have got it
    and they carry all majour brands aswell:
    Bosch ,Seimens, VDO, etc etc
    also try MSCN (Motor Sport Connections) they stock a fair bit of efi stuff as well
    http://www.mscn.com.au
    and both of these compannys can ship interstate
    Boost Me, Then Double Clutch Me, Till I Can Get My...Loss Of Traction
